Di450 edh-3 pulls 2 sheets or more sometimes
  • Export100
    • Aug 2025
    Does anyone know which parts need to be replaced to fix this?
  • rocky246
    • Feb 2007
    • 91
    Is there a seperation pad in front of the seperation roller? If not, that needs to be installed. Konicaminolta had a bulletin on that a loooong time ago. Bulletin #3379. Pad # 4641-3521-01 and Guide # 4641-3520-01. Also replace the seperation roller and feed rollers.
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • Export100
        No there was not and I just ordered those two parts. I did replace the separation roller and it helped but did not resolve the problem.
        I will update you upon the installation of the guide and pad you suggested.
        Thank you for your expertise.
        • Export100
          Re: Di450 edh-3 pulls 2 sheets or more sometimes
          Thanks for that info. I fixed it with new rollers. However, I also purchased the
          plastic guide you suggested but I have no idea where it goes. Also I cannot locate the bulletins you mentioned.
          Thanks for your knowledge.
          Scott
          • Export100
            Re: Di450 edh-3 pulls paper but crumples and does not exit
            Any thoughts as to a fix? I've looked for paper etc stuck in there but it looks ok. Anyone have a thought?
            Thanks!
            • rocky246
              • Feb 2007
              • 91
              It is on Konicaminoltas website in SSD. Search solutions under DI550 and type in EDH-3. If I find the bulletin I will post it. I think thats where i found it the first time.
              • Export100
                Thanks! I did fix the EDF by shoving a piece of cardboard through the exit a few times. It must have been a staple or something stuck in there. I never did see exactly what it was that caused the crumpling but who cares, its fixed (for now).
                • rocky246
                  • Feb 2007
                  • 91
                  This is the bulletin about the pad and guide.
