7135 F35-1 Release latch?
  • mrfuser
    • 1617
    Okay, rebuilt fuser due to many error codes on fuser. We still get an F35-1 and we go into 25 mode and clear it, but it comes back. Manual says we must "release latch" or it will return. What does "release latch" mean? Open and close front door or something?
    Thanks all
    Kelly
  • SmellsHot
    Head Tech
    • 512
    25 mode, DIPSW settings, bit 3-1 change to OFF
    Did you replace temp sensor and/or thermostat?
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • mrfuser
      • 1617
      I clear the code, but the book says if we don't "release the latch" the code will come back. What is the "latch" it is referring to?
      Kelly
      • SmellsHot
        Head Tech
        • 512
        Clear it by resetting it in DIPSW's? (this is the latch they are referring to)
        Did you replace sensors?
        • mrfuser
          • 1617
          No, they meter out fine, should we replace anyway?
          Kelly
          • SmellsHot
            Head Tech
            • 512
            absolutely! Thats why your getting errors. If you can replace the temp sensors and stat, if your being cheap start with sensors and cleaned stat head
            • CraigW
              • Dec 2010
              • 417
              White thermistor leads = BAD
              Yellow thermistor leads = GOOD
              • mrfuser
                • 1617
                Good to know on the leads. I had a set from a 7145 I can throw in there.
                Thanks guys!
                Kelly
