Re: Konica IP511A system code
Connect via the serial port using TeraTerminal while you see the Memory check type "KA" (without quotations) this will boot it to a DOS Prompt change Derectories and type "Restore" this will load the previous backed up version of the system code. Usually works as long as the HDD is not bad.
Trying to install firmware via KMBS method is tough on this box-Leave a comment:
Been awhile on this but if I remember it's through a parallel port. I will send you the manual email me woxner@copytronics.netLeave a comment:
I have a customer that keeps getting SC4901 and 4904 codes on their 7255, and the problem seems to be corrupted system code on the controller. Problem is, I can't locate a service manual for an IP511A, so I don't know the procedure for reimaging the controller HDD. Any ideas?
