FK 502 problems dialing out
  • Buff it out
    • Jul 2011
    • 23
    [Misc] FK 502 problems dialing out
    Encountered no dial out from C450 with 502 fax installed. Customer just installed new system from
    AT& T called U_VERSE running digital line sounds like VOIP. Can receive faxes just fine, we get dial tone
    but dialer will never break dial tone. Have switched polarity on phone line, did not help. Any fixes for this problem?
    Appreciate any and all help. Buff it out
  • kingarthur
    • 1305
    Re: FK 502 problems dialing out
    i always thought that you needed an analogue line for faxes, which doesn't explain why you can receive but not send, we normally change the fax lead when that happens
    • Buff it out
      • Jul 2011
      • 23
      Yes,you are sure right on an anolog type line. This situation gets stranger by the hour.
      I put a small Imagestics fax copier next to thjis unit and it works fine. Im beginning to
      think that I have not set something correctly or we have a defective board. In looking
      at some older post just the smallest option can wreck this thing. Used the install manual
      for this option Depending on level of firmware these boards can run on digitial line, but
      not a high degree of reliability What did you mean by the other line? Thanks for your reponse
      Buff it out
      • kingarthur
        • 1305
        the fax leads that were originally supplied with the fax kit didn't always work...they either allowed you to transmit & not receive or vice versa
        • Buff it out
          • Jul 2011
          • 23
          Understand now what you are referring to. We do not have those leads since
          this copier was moved to different location. Did check that out and actually
          reversed the polarity ie= known in the telco industry as tip and ring or red and green.
          did not make any difference. But I have seen the time in different central office
          gear that you could not dial out, you would hear dial tone and you could not dial.
          We do have dial tone but the board will not dial out. Feel like an option is not set correctly
          and have go thru a lot of features as in the manual- too much reading between the lines
          required by mfg.
          • Mr Spock
            Vulcan Inventor of Death
            • Aug 2006
            • 2064
            Officially only an analog phone line is supported.
            Can you dial using the off hook mode and manually sending?
            check the market area in the service mode
            initialize the fax board about three times.
            • Buff it out
              • Jul 2011
              • 23
              Have not tried to do the manual mode, will do as you advise
              and see if the initialization will correct the problem. It would appear that
              if it receives fine which it does we should be able dial out.
              Thanks for the help
              Buff it out
              • Buff it out
                • Jul 2011
                • 23
                Initalization of fax 502 did change some things, but did not help the dial out
                problem. Not being that familiar with this particular fax, does it operate like other
                fax units in that when you are dialing manually do you hear the tone pulses just like
                a standard telephone? All I hear is a click maybe, no tone. Understand from a friend
                that this unit will not run on a digital line period. But the small imagistics fax is
                sending and receiving fine. Whats the deal here?
                Buff it out
                • copytechman
                  • Nov 2008
                  • 926
                  Did you try turning off dial tone detection?
                  Regards!
                  A.
                  • delboy10
                    • Jun 2010
                    • 43
                    Hello,
                    First I would check if the machine and the fax have the latest firmware, and then check if the Dial Tone Detect function is OFF. From my experiences, with VOIP you have to turn Dial tone detection OFF. Also, you have to get into service mode and make these changes:
                    VoIP is still not supported offically by Konica Minolta, but may work in some instances.Performing these suggested settings may solve the problem. Follow the step-by-step procedures:
                    From Service Mode:
                    • FAX Settings => Communication => Protocol set "ON" for the "V.29 EP Tone" Protocol and set "OFF" for all other faster protocols.
                    • FAX Settings => Communication => Others we have set "OFF" for the "ECM Function"
                    • FAX Settings => Function Parameter => Address "000e0012 = 01111000 (decimal 78 = 120 sec) for T1 Timer for Calling
                    • FAX Settings => Function Parameter => Address "000e0013 = 01111000 (decimal 78 = 120 sec) for T1 Timer for Called
                    • System 2 => Software Switch => SoftSwitch 21 Bit 5 =1 (HEX 20 = over 4.5 sec) for T4 Waiting time between start Identification
                    To Turn the Dial tone Detection function OFF is also in the service mode. Fax=>Line2=>Network=>Network Setting 2=>OFF of Dial tone Detection.=>End=>Exit and Hard Reboot.
                    Delboy
                    • Buff it out
                      • Jul 2011
                      • 23
                      Will try these changes Monday at customer site. It's good to have advice
                      from one who has the knowledge. Thanks Buff it out
