c351. c2152 error
  • mrfuser
    • 1617
    c351. c2152 error
    C351. C2152 errorThis error won't clear. Swapped belt, still have error. Tried open close door, power down, still won't.clear. any ideas?ThanksKelly
  • JustManuals
    • Jan 2006
    • 9838
    Re: c351. c2152 error
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • Ianizer
      • Jul 2011
      • 380
      Perform Trouble Reset.
      You know- The power on while doing the thing with the thing?
      Touch the thing, see deal, do it again. Poof! Worky-worky.
      That, or you left some tape on the Xfer belt.
      In which case you need to do the thing with the deal anyway.
      HTH
      -I
      My name Peggy.
      You got problem?
      • SPBE
        • Sep 2010
        • 70
        HTH
        -I
        Yeah, what he said.
        • rprem
          • 49
          hi
          have u checked the sensor on the right side of the transfer belt it must be problem,or otherwise install transfer belt and dont put both the screw just put one screw on the right side and close the door and check it
          Head Lines Are Made When Dead Lines Are Met
          • mrfuser
            • 1617
            Sensor on rear wall of copier where the transfer belt slides into was completely coated with toner. Cleaned it off and works fine.
            Thanks all!
            Kelly
            • 1FRY1
              • 51
              Just deleted it as I see youv'e fixed it
              • Ianizer
                • Jul 2011
                • 380
                Thanks all!
                Kelly
                Another stone-cold frikkin copier guru saves the day!
                You RAWK, Mr. What a maniac.
                High-fives and Rockstars all around.
                Dontcha just love it when you're right?
                -I
                My name Peggy.
                You got problem?
