C6000 refuses to print multiple copies of jobs
  • adeyemi
    • 379
    Hello,
    When jobs are sent through certain packages, the machine (C6000) refuses to print multiple copies, e.g 5 sets of a 20 page document. It simply prints the first set and the job seem to hang on the printer. These happens with Microsoft office packages and with PDF files. It works well with CorelDraw files. what could be the problem? Thanks.
    Dgtal
    • 22995
    Re: C6000 refuses to print multiple copies of jobs
    What print language/emulation are you using? Have you tried the other option? =^..^=
    • adeyemi
      • 379
      I'm using PCL, if that is what you mean. Are you suggesting PostScript driver?
      Dgtal
        • 22995
        Actually I was hoping you would say PostScript, so I could say,"Try PCL!"
        How about a image memory issue?
        Sorry, that's all I had. =^..^=
        • adeyemi
          • 379
          So what if its an image memory issue...increase the RAM? By the way, it's an internal controller. Thanks
          Dgtal
            • 22995
            Upgrade or replace, depending on the amount you already have. =^..^=
            • adeyemi
              • 379
              Ok thanks, but what baffles me is why CorelDraw works?
              Dgtal
              • RRodgers
                • Jun 2009
                • 1942
                Change the number of pages you want to print in the print driver window NOT the print screen (ie hitting file then print opens the print window) you get the print driver screen when you hit properties.
                HTH
                • adeyemi
                  • 379
                  ok....quite reasonable
                  Dgtal
                  • kalindd
                    • Jun 2008
                    • 189
                    Which IC you're using?
                    • adeyemi
                      • 379
                      IC601
                      Dgtal
                      • adeyemi
                        • 379
                        IC601
                        Dgtal
                        • kalindd
                          • Jun 2008
                          • 189
                          As far as I know PCL is not supported yet on Ic-601.
                          I can't find any pcl drivers on konicaminolta.eu or konicaminolta.us.
