C250 ERROR c0301 suction fan motor
  • yannii33
    • 121
    Is this suction fan the m12 fan in this machine where is it located. keep getting this error code does anyone have a solution for it.
    Thank You
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: C250 ERROR c0301 suction fan motor
    from C250ver_3_08.pdf
    It is located under the filter on the upper rear of the box...clean it!!!
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • yannii33
      • 121
      [QUOTE=acusso1234;245644][ATTACH]11781[/ATTACHi
      I have cleaned it and it spins should I replace it?
      • Hansoon
        • Sep 2007
        • 3374
        Could this solution be of help?
        http://www.copytechnet.com/forums/ko...-di-450-a.html
        Hans
        • acusso1234
          Tecnico
          • Dec 2008
          • 250
          You could reverse M12 with M13, why are the same, and see if the error code changes or not. This way you can tell if you have to replace the fan or the card. But if there was an ICP burned on the card, the code would be fixed and not intermittent as in your case.
          • yannii33
            • 121
            Is it PWB M that need to be replaced for this code because i tried a new M!2 fan and code still comes back
            Thank You
            • habik
              • 2013
              Thank You
              ahh bugga: I have C351 and the same Issue:
              I ordered new fan...and in the meantime tried one from another machine, which wasn't installed "also" properly wires tend to get squished between the mainframe of the door and the metal support plate which is also acting like a earth..
              I also tend to find the foam touching the fan-- every now and then and I think this could cause that intermittent issue.
              If I cut it out that the suction will be not as good and could cause build up of paper dust.
              FW or anything simmilar did not work for me...unless there is a specific solution to this. Probably Board..(ouch)
              Firmwares HERE
              • DCPS
                • Mar 2008
                • 116
                Originally posted by acusso1234
                [ATTACH]11781[/ATTACH]
                This is wrong. The right one is Suction fan motor M10 (9313 1000 72) 2011-09-23_094319.jpg
                • acusso1234
                  Tecnico
                  • Dec 2008
                  • 250
                  Originally posted by DCPS
                  This is wrong. The right one is Suction fan motor M10 (9313 1000 72) [ATTACH=CONFIG]11925[/ATTACH]
                  Yes you are right but, reading the first post...he asked for M12 that is located in the position that we know.
                  • Toxic
                    • 697
                    I have the same problem, error c-0301.
                    Machine is C252.
                    Machine was working ok before holidays and after few days in cold room it shows error and jam paper when paper goes from paper tray to registration section.
                    I visually check 3 fans on the back of machine, they are working,somebody mention pwb-m,is it a problem?
                    • Toxic
                      • 697
                      I have to reply to myself
                      It was fan in right door M10.
                      It was stucked.
                      • Woxner
                        • Jul 2011
                        • 841
                        although these are turning there is a circuit to measure speed. i have never replaced a board for this. always been the fan
                        • Toxic
                          • 697
                          I never had this error till now on this one machine.
                          This fan did not turning at all and after some hand rotating it starts.
                          Maybe i will have to replace at end because it have some "buzzing" sound when working.
