Hdd install and initialize
  • erb
    I have a c 252 that has email issues, i place 5 pages in adf and it sends 5 1 page emails, i checked and the hdd was unplugged, the previous tech said it had a bad hdd, i want to replace the hdd and i need to know how to initalize the hdd when i replace it, can someone help.
  • TheOwl
    • Nov 2008
    • 1732
    Re: Hdd install and initialize
    Just put in the new HDD, enable the HDD through service mode and then do a physical format followed by a logical format.
    • erb
      thanks for the info, can you email me the proceedure for that, im not real familiar with konica minoltas.
      • RRodgers
        • Jun 2009
        • 1947
        Just buy the manual from manuals4you and then you'll have your answer and future answers.
        • TheOwl
          • Nov 2008
          • 1732
          As above, or look through the forum for how it is done as it is most likely posted somewhere all ready.
          • erb
            i did buy the service manuel on line, can you please direct me to the location in the service manuels (there are 2) on the previously stated directions on installing a new hdd.
            THANK YOU
            • mervyn
              • Jul 2011
              • 90
              You dont need a hard drive to e mail scan , set the document type in scan to mustiple page pdf and it will scan as many as the it allow.
              • erb
                I couldnt find a screen in the machine to change the setting to multi page originals
                • mervyn
                  • Jul 2011
                  • 90
                  Select Scan-scan settings -and you will see a screen for type of original , touch that and you will see pdf, tiff etc , to the right it will say single or multi , select multi and you should be good .
                  • erb
                    i still couldnt find an option for single/multi pages any place in any screen, i did install the hdd, set machine in service mode to hdd, then did physical format, then logical format, when i did the logical ithe op panel went blank and wouldnt return, i waited 10 min and still no op panel. is this normal, i left the machine in the logical format running last night in hopes it would finish and have the machine reset this am by another tech. can i get some please get some help on this.
                    • kingarthur
                      • 1385
                      THANK YOU
                      why dont you just read the manual.....thats the reason for getting it......next you'll be asking someone to wipe your backside for you.....
                      • erb
                        thanks king you were a big help
                        • kingarthur
                          • 1385
                          Join DateSep 2011Locationphoenix azPosts7 Rep Power0
                          thanks
                          maybe you can help me with my backside with your tounge
                          thanks again for all your help
                          is this the sort of private messages you like to send.......if you read the manual...instead of getting a manual & asking where you should read...maybe i might help!!!
