uneven density in 6500
  • levino
    • Jul 2009
    • 38
    [CQ] uneven density in 6500
    Hi
    my km 6500 magenta and cyan color varies from side to side ie from left to right margin(parallel to drum)Replaced drum developer transfer belt transfer rollers upper and lower and charger too.Like uneven density correction in 6501 any thing available in 6500?
    pls help
  • kalindd
    • Jun 2008
    • 192
    Re: uneven density in 6500
    You can use shims to distance the corona from drum. Google this pn A03UP46200
    • Albonline
      • Sep 2008
      • 1144
      tape works as well.
      • RRodgers
        • Jun 2009
        • 1947
        Corona wires are known not to be installed correctly at the factory on that model. Double check the wire.
        • levino
          • Jul 2009
          • 38
          Hi Rodgers,
          the corona wires are checked and confirmed already,because i already met with that.
          Albonline,
          Can you please explain how I can use the tapes.
          • Albonline
            • Sep 2008
            • 1144
            Put tape over pads on cro blocks. to adjust distance between charge grid and drum.
            • RRodgers
              • Jun 2009
              • 1947
              Originally posted by levino
              Hi Rodgers,
              Albonline,
              Ahhh so you've seen when they come brand new not set up correctly? Yeah, it's a pain. I've learn to always check them now on all the one's I get.
              Sorry I wasn't the one that suggested the tape but I can see how that should work.
              GL
              • levino
                • Jul 2009
                • 38
                Thanx Alboline,
                Ill check and come back!!!
