Bizhub 250 C3451
  • mrfuser
    • 1626
    Bizhub 250 C3451
    Okay, client ran some thick stock, then machine went into a C3451 code, won't reset. Tried button by CF Card and all. Is complete fuser shot or what?
    Kelly
  • mo0651
    • 1054
    Re: Bizhub 250 C3451
    if u dont have a fuser on another machine to swap, check for continuity on the thermostat in the fuser. U must disconnect the wires from the t-stat, or u wont get a good read. U can do the same for the lamps and find out.
    • boanda
      • Feb 2011
      • 79
      Just had that problem, thermostat was bad, just exchanged from old fuser and now works fine
      TH3 paper went all over the roller and make damage, in mu case
