cs pro 2080 c0010 code
  • digicor
    • Jul 2008
    • 1159
    this code refers to the second drive motor, as far as i can check the relays and the fuses all check out ok,is there any other situation that would throw this code or is it the motor.I have re set the machine as well from the back ... thanks
  • pedol
    Re: cs pro 2080 c0010 code
    check PWB A and the main motor (M1), if its heavy rotation, replace the main motor (M1)
    thanx
