problem with bizhub C250 with a C9401 error code
  • bluesky2000
    • 95
    Hi all ...
    i have 2 Solutions but i need some help..
    I've read older posts about this exposure lamp not lighting issue can some one show my in a (( IMAGE )) where is the exposure lamp ?
    now i have this solutions form some web :
    The output from the CCD Sensor is a predetermined
    value or less during CCD Sensor gain
    adjustment.
    1
    Check the flat cable for proper connection and
    correct or change as necessary.
    2
    Change PWB-C
    the next solutions
    The original glass is removed from the machine or the white reference strip is damaged.
    Ensure that the original glass is installed properly on the machine and the white reference strip is correctly positioned. Replace the original glass as necessary.
    where is the CCD ?
    now can some one show me the solution in image relay i need help >>
    thanks all
  • kingarthur
    • 1364
    Re: problem with bizhub C250 with a C9401 error code
    please tell me that you ARE joking...you do really know where the exposure light is.....if not....well when you take a copy...its the bright light underneath the glass.....
    • mervyn
      • Jul 2011
      • 90
      Sounds to me as if you REALLY need to call a tech .
