Konica c451 with IC409
  • Cay
    • Aug 2025
    [Error Code] Konica c451 with IC409
    I recently reload system code via USB on the IC409. Applied suggested patches.
    Under Utility/Counter>Controller Details, I get the following message:
    Maitenance
    Requried D-1
    Does someone know what that message means? I haven't been able to find anything on it.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Konica c451 with IC409
    I can not find it but will suggest clearing the cmos of fiery and making sure you made the thumb drive correctly.
    • Cay
      I will try clearing the cmos.
      FYI, this message did not appear right after the system reload. It took a couple of days before it showed up.
      • scottybbb
        • Dec 2010
        • 126
        D-1 is a warning code or P-code telling you to clean the slit glass.Check under counters in service mode.
        • Cay
          Thanks Scottybbb, that was it. I assumed it was a fiery code. If I had opened Command WS it probably would have made it more obvious to me.
          Thanks again.
