Backgrounding on DI850 or Imagistics DL850
  • rlr42173
    • Mar 2007
    • 28
    [CQ] Backgrounding on DI850 or Imagistics DL850
    Hello I have a Di850 that has gray background.
    I have new developer, wires, decent drum, have run all peculiarity settings, Voltages in 36 mode are in line. This happens on Prints or Copies from glass.
    See picture for example.
    It is definitely worse on the 2nd side of copies, but all the same it is there on both sides. I just don't know what to try next. Tired of wasting time on this problem. The TCSB is actually pretty clean when I inspect it after running a lot of copies. What could be causing this?
    Any help is welcomed and appreciated.
    Thank You
  • potro_salvaje
    • Sep 2010
    • 23
    Re: Backgrounding on DI850 or Imagistics DL850
    Thank You
    Hi sir, i have the same problem, if u solved this trouble please tell me how?
    • scottybbb
      • Dec 2010
      • 126
      Replace the entire developing unit.
