Bizhub C350 Jam Tray 3 Only
  • mrfuser
    • 1625
    Getting a jam from tray 3 only. Top 2 trays work great. Swapped out feed head assembly, still jams. Code shows Tray 3 and Vertical Transport Jam, again, ONLY from TRAY 3.
    Any thoughts?
    Kelly
  • kingarthur
    • 1383
    Re: Bizhub C350 Jam Tray 3 Only
    have you checked the mylar strip on the tray itself..had a problem with that being worn before
    • mrfuser
      • 1625
      Swapped.trays, same.result
      • mo0651
        • 1054
        where is the paper at? sensor in feed unit...had a broken one once. Does it get to reg roller?
        • RRodgers
          • Jun 2009
          • 1947
          Replace the one-ways that are right on the feed and sep tires.
          • mrfuser
            • 1625
            Does not activate paper lift. Just shows jam when try to copy or print.Does not show error until you try to copy and.only from try 3. I have swapped.lift motor , board and sensors for back showing drawer in place. Still nothing. No lift.
            • mrfuser
              • 1625
              no help here? Must be someone out there that has done this job.
