Bizhub C220 Bypass Tray Sensing Problem.
Re: Bizhub C220 Bypass Tray Sensing Problem.
You will need to download the animation data from kmbs tech database and reload it to the copier. You may also need to reload the firmware. If you are a konica minolta tech you will know where to find this , if not please dont ask me to send it , you would need to get a qualified tech to install it . You may also need to do a complete setup as if you were setting up a new machine . -
12.4.20 Manual Bypass Tray AdjustmentA. UseB. Procedure1.Call the Service Mode to the screen.2.Touch these keys in this order: [Machine] → [Manual Bypass Tray Adjustment].3.Touch [Max. Width].4.Load the bypass tray with paper having a width of 297 mm.5.Press the Start key and check that the results are [OK].6.Touch [Min. Width.].7.Load the bypass tray with paper having a width of 100 mm.8.Press the Start key and check that the results are [OK].✽ Make the adjustment again if the results are [NG].
Everyone has the right to be stupid. Some people just abuse this privelage more than others
Yup. The Clear All Data just wiped out the audio and video files, creating a second much more labor intensive problem. The next time someone tells you to do an All Clear, you should think about this event.
"Hmmmm. I wonder if I might create a new much larger problem by doing an All Clear." I only had to do this once to learn.
Like mervyn suggested you'll have to re-load the audio and video files, then do a complete setup like it's a new machine. The manual covers this nicely.
Like SmellHot said, the manual tray adjustment is what you needed for the original problem.
I think the real lesson here is, not all advice is good advice. =^..^=If you'd like a serious answer to your request:
Maybe he worked on Kyoceras..format HDD, initialize all data, swap boards all day long...who cares! machine would power up and work, just need to tweak certain defaults back to preference.
Clear all data on a Konica is not worth doing ever, it will never fix anything.Comment
Also make sure the bypass tray is selected in the auto tray selection setting in user mode.
DarrenComment
My only concern is that those reference values may be useless. You have to replace one or more developing units. =^..^=If you'd like a serious answer to your request:
Restoring the movie data will bring back the animated guidance messages, but is unrelated to your toner density problem. The Clear All Data wiped out the developer density reference value. When you re-set up the machine you will re-establish the toner density reference values.
There is no toner density problem, it is toner level in toner cartridge sensing problem. Even though two toner cartridges are almost empty, machine is showing / sensing it as full (either in touch panel OR even in pagescope )
. I just want to know if I restore Animation data back, will toner % in toner cartridges will show correct values.
Regards & Thanks
AjitnComment
First of all, did you set this machine up as new yourself? if yes, did you do the following
did you follow up the set up step by the manual?
on the machine is using KM toner or 3rd party? if 3rd party toner that might be why the problem on the toner level sensor not working.Comment
I had this no recognising SRA3 problem and found this tread before oppening my manual.
my mistake was trying to make the setup using an A4 (297 width) and "the mistake" A5 (1/2 A4) for smal width
the information about 100mm minimum width saved a trip to my car.Comment
