C352 Pouring cyan
  • bkamoga
    • Oct 2011
    • 31
    [Misc] C352 Pouring cyan
    l have amachine c352 its pouring cyan on all the print outs
    the image comes out but the whole paper come out with cyan
    i hve changed the drum on the imaging unit and but still the same
    problem, l have changed the l nterchanged the i maging units buy
    puting cyan in magenta and magenta in cyan but now it came in
    magenta. l hve changed the print head but still the same problem
    but when i stablize like 5 times cyan disappers completely after many print
    outs it comes back.But still it keeps on asking me to replace cyan toner every like
    after five prints.
    some help pliz i will be very grate full
  • Zeldaman
    • Mar 2011
    • 946
    Re: C352 Pouring cyan
    after five prints.
    Hi there!
    Had the same sh.. with yellow: check the HV-contacts especely the springs. If they are not 100% in place you get this phenomen without any troublecode.
    Greetings...
    • kingarthur
      • 1341
      i'm not sure if i've read this right...you say you've changed the drum, but not the imaging unit, you swapped the devs over betweeen the cyan & magenta units, then the problem occurred on the magenta unit....in wihich case it has to be the imaging unit..
