About Efi Fiery Controller (IC-306)
  • gurko_gg
    Prod.Line Technician
    • Sep 2011
    • 43
    Hello,
    I have ic-306 Ver 2.0 controller
    But i lost System and User Software CDs
    Anyone help me about Cd images
    Regards.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Re: About Efi Fiery Controller (IC-306)
    You will need the ISO V1.1 then Patch to V2.0
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • gurko_gg
      • Sep 2011
      • 43
      i can find v1.1 CDs.
      But i havent V2.0 patch Cd.
      we upgraded V1.1 to V2.0 (its came a pack)
      Cds in the pack but i didnt find the pack.
      Ru send to me V2.0 Patches?
      Regards.
      • gurko_gg
        • Sep 2011
        • 43
        i inserted system software cd (V1.1) to ic-306 for format.
        ic306 say to me "This DVD not support at this platform."
        • oxident
          • 74
          It would be great if anyone could share the 2.0 update patch. I also lost the CD ... but my BIOS is already upgraded :-(
          • oxident
            • 74
            Okay, forget about my last post. Found the DVDs again... Anyway: There was no "update patch". It was a complete re-install using system image 2.0
            • Mick01
              • Nov 2012
              • 362
              In regards to the "patch" files. I would remote into the Fiery and update using the update utility. This will ensure you have all the latest patches installed.
              The fiery needs to have "internet access". Once you open the utility there is a "check now" button. You can also set up auto downloading and installation of new patch files when they are available.
              • oxident
                • 74
                Yes, but in this case, it's a paid patch (Sys 9 to 9R2) which isn't available on EFI's site.
                • Mick01
                  • Nov 2012
                  • 362
                  Hi,
                  I am trying to understand what you are referring to. The upgrade from Version 1.1 to version 2.0 is not a "patch" upgrade. It is upgraded using a single use dongle and installing extra memory inside the IC-306, once this upgrade occurs you cannot go back to version 1.1 as it updates the bios. If you need to reload the system software it will only take the version 2 system disk.
                  • oxident
                    • 74
                    Yes, that's exactly what I wanted to say
                    • zunamiwave
                      Hi I wanted to know if you have an image you can share with me on this. The software I have would not boot up no more or get an error once its tries to boot. Would it possibility if you can share the image if you dont mind?
                      I would appreciate the help.
                      • jpablo_mza
                        • Jun 2018
                        • 30
                        Dear, I need the version 2.0 of that fiery (Pro80), I lost the discs and xp does not start, someone will have the images ?? Thank you very much for your help
                        • sisirakj
                          • Mar 2020
                          • 9
                          do eny one has Konica fiery IC-306 system software
                          - 45122757 v3.01 System Software 1
                          - 45120171 System Software 2 disc that came with v3.0 upgrade kit
                          - 45120172 System Software 3 disc that came with v3.0 upgrade kit
                          - 45122758 v3.01 User Software
                          - Windows 7 Product Key that came with v3.0 upgrade kit
                          • Synthohol
                            Certified Konica Expert
                            • 5847
                            i sent a PM with what i had to help.
                            hope it helps!
                            thanks for being a contributor!
