Bizhub 363 finisher removal
  • Rustmeister
    • Aug 2025
    [CQ] Bizhub 363 finisher removal
    I have a customer here who wants me to remove his finisher. I turned off the machine, unhooked it, and turned it back on, but it still tries to feed to the finisher. Is there any settings I need to change?
  • groovy
    • 179
    Re: Bizhub 363 finisher removal
    Normally konica's machines are auto-configured, so nothing to deal with menus...
    Just today i went to remove a finisher from a biz 350: power off, unhook, remounted parts of case missing to the finisher and go!
    • mo0651
      • 1054
      Did you take out the transport section of the finisher?
        • 23009
        Yep. I'll bet you left the bridge unit installed. It's considered part of the finisher. You'll probably want to order up that arched plastic piece where the paper lands so it will stack properly. =^..^=
        • Rustmeister
          I do believe you're right - will check that next time I'm out there.
          Ya know, back in the day those bridge units used to come out with the stacker....
          Thanks!
