C253, C353 and others
  • AlSyed
    NewBee
    • Aug 2010
    • 41
    [Misc] C253, C353 and others
    Hello Friends,
    In some copiers when I print Config Report and Demo Page I dont have any problem but when I try to print Meter Count and consumable report copier just freezes and nothing happens untill I restart the copier. all other fuctions are normal like making copies and printing other stuff but just printing Meter Count and consumable life is a problem. Any suggestion will be appreciated please.
  • RRodgers
    • Jun 2009
    • 1947
    Re: C253, C353 and others
    I've had a machine with a bad NVram do that once.
    • mo0651
      • 1054
      I think the latter 2 reports need to be printed on landscape paper from tray 1 or bypass.
      • Albonline
        • Sep 2008
        • 1151
        landscape paper in either drawer
        • ni311
          • May 2008
          • 658
          Is it just freeze, the reset button or any other button won't work or you just can't print these pages (the start button is ot green / blue)?
          Konica Minolta Error Codes - Explanations and Solutions
          • AlSyed
            NewBee
            • Aug 2010
            • 41
            I have more then 20 of these in stock as I am wholeseller and Exporter. Most of them print consumable life report an Meter count with no problem, its just some of them go to freeze. Nothing happens, no button or screen works and have to restart the copier. Again Copy, Print Demo and Configuration page prints fine.
            • mo0651
              • 1054
              Has the HDD been de-installed or removed?
              • habik
                • 2013
                I would just format HDD, flash with latest firmware and do version up on HDD..
                then
                NV Ram recovery.
                Firmwares HERE
                • Don N.
                  • Nov 2011
                  • 409
                  I'm thinking the paper direction as previously posted will solve it.
                  • AlSyed
                    NewBee
                    • Aug 2010
                    • 41
                    Dear Friends, It came upto HDD. End user took out HDD and I did not know about it. I installed HDD, Format and all Menues came out and it started to print everything as it should have. Tnx fo rall the help.
