Konica 7035
  • stevee104
    • Mar 2007
    • 214
    Konica 7035
    I have a machine that has shaft assembly that drives the fuser unit that has wore it self down along with the bushing egging out.In the parts book on page 14 the driving unit the shaft is gray out with no part number, can anyone tell me for sure that the part is not made, it goes with gear 31 and gear 22 on parts page 14.
  • kingarthur
    • 1369
    Re: Konica 7035
    if you have access to the "infohub", lookin the "ocp"....it has 2 part numbers for that part, the old part is 26na15140, which has a "holder" at each end p/no 46607602, the new p/no is 40la15140 which has a "bearing" at each end p/no 26na1728. its under parts modification number KOM090119...
    • stevee104
      • Mar 2007
      • 214
      Re: Konica 7035
      No we are not a konica dealer so all i have is a service and parts manual.
      The new part number you posted 40la15140 is this the right number i just notice a l after the 0.
      thanks
      • kingarthur
        • 1369
        Re: Konica 7035
        yes it is an "L"...if you have the bushings...then it seems it's the old part number, or else i'd order the bearings as well...just to be on the safe side
        • stevee104
          • Mar 2007
          • 214
          Re: Konica 7035
          So i am going to order the new part number 40la15140 , and this does not come with the new bearings so
          i will have to order to new ones is this correct. Didn't know if this was a kit or not.
          • stevee104
            • Mar 2007
            • 214
            Re: Konica 7035
            Is the part number for the bearing right , my supplier said it was invalided number.
            • ni311
              • May 2008
              • 658
              Re: Konica 7035
              The code is correct:
              40LA15140 - FIXING INPUT SHAFT ~ 2 Euro
              Konica Minolta Error Codes - Explanations and Solutions
              • stevee104
                • Mar 2007
                • 214
                Re: Konica 7035
                Can you me a pdf of the bulliten so i can get the part number for the bearings.
                • CraigW
                  • Dec 2010
                  • 417
                  Re: Konica 7035
                  These are what we stock...they are for the early models (with bushing) before they went to a bearing.
                  26NA15140 Fixing Input Shaft
                  466076020 Paper Feed Shaft Holder (bushing)
                  If it is the type with a bushing you have to stay with a bushing as the bearing would not fit the frame opening.
