I have a machine that has shaft assembly that drives the fuser unit that has wore it self down along with the bushing egging out.In the parts book on page 14 the driving unit the shaft is gray out with no part number, can anyone tell me for sure that the part is not made, it goes with gear 31 and gear 22 on parts page 14.
Konica 7035
Re: Konica 7035
if you have access to the "infohub", lookin the "ocp"....it has 2 part numbers for that part, the old part is 26na15140, which has a "holder" at each end p/no 46607602, the new p/no is 40la15140 which has a "bearing" at each end p/no 26na1728. its under parts modification number KOM090119...Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away... -
Re: Konica 7035
yes it is an "L"...if you have the bushings...then it seems it's the old part number, or else i'd order the bearings as well...just to be on the safe sideTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
Re: Konica 7035
The code is correct:
40LA15140 - FIXING INPUT SHAFT ~ 2 EuroComment
Re: Konica 7035
These are what we stock...they are for the early models (with bushing) before they went to a bearing.
26NA15140 Fixing Input Shaft
466076020 Paper Feed Shaft Holder (bushing)
If it is the type with a bushing you have to stay with a bushing as the bearing would not fit the frame opening.Comment
