C352 Changed administrator code
  • Dickie
    • Nov 2011
    • 190
    Have just bought in a used C352. The previous servicing dealer appears to have changed the administrator password from 12345678 and has also changed the service password from 00000000. Does anybody know if there is a way around either of these or a backdoor code that works on all machines regardless of the changes ? I would assume there is at least a backdoor for engineers into the administrator mode as you cannot legislate for end users changing that. I know if CE authentification is changed then it's a new boards job but have never come across this before as i've never changed any myself before or known anybody stupid enough to do so!
  • kingarthur
    • 1351
    Re: C352 Changed administrator code
    the code to enter the tech rep mode isn't 00000000, but the code using the "stop" button, then you go into enhanced security when in tech rep to change the admin code
    • Dickie
      • Nov 2011
      • 190
      On minolta machines if enabled; after stop 00, stop 01 the machine then prompts for an 8 digit password code which is normaly 00000000 but on this machine is not! This is stopping me getting fully into service mode to allow to go to enhanced security (0C) and reset the administrator password. This is why I am currently stuffed!!!!
      • Albonline
        • Sep 2008
        • 1150
        try 92729272
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • Dickie
            • Nov 2011
            • 190
            Have already tried CE authentification code as well in both fields.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              ce password is in NVRAM
              you can do an NVRAM initialize using the the card, but be aware of the BS involved in resetting up the machine.
