bizhub 350
  • billkellner
    [CQ] bizhub 350
    copis off the glass are ok, copies thru the doc feed are light.. I have cleaned the glass & mirrors. Is there an adjustment?
    Bill
  • JustManuals
    • Jan 2006
    • 9838
    Re: bizhub 350
    Paul@justmanuals.com
    • kingarthur
      • 1385
      Re: bizhub 350
      go into utitlity mode, then users settings & adjust the RADf settings
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Re: bizhub 350
        It is on the last page of user settings, it is the scan adjustment. The default is the left choice, select the right one, there are only two.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Re: bizhub 350
          yep, there are 2 settings for both the flatbed scanner and the adf.
          one has a wider range of grayscales available, the other has less and will ignore grays below a certain density.
