bizhub 601 jam 14 in adf
  • mrfuser
    • 1617
    Everything looks good, but paper starts to feed and stops before going down.
    Any thoughts? Shows jam 14
    Kelly
  • JustManuals
    • Jan 2006
    • 9838
    Re: bizhub 601 jam 14 in adf
    Paul@justmanuals.com
    • joaopauloooo
      • 44
      I'm having the same problem here, did you manage to find a solution?
      • allan
        RTFM!!
        • 5462
        bend the cover switch on the front side up a bit...
        If you hold the cover down and it feeds that is the problem.
        Whatever
        • copyman
          Owner / Technician
          • Sep 2005
          • 4671
          Blow off sensors (one sits down inside top cover and hard to see). Also check white/blue one way gears (feed & registration), clean pin bearings, scuff up shaft and put one way gears back on.
          • DSharpe
            • Apr 2018
            • 36
            If you lift up the cover on top of the adf there is a switch on the front side for the open and closed state of the door. U can try reforming that metal to make more contact or replace the switch itself.
