bizhub 350 pc402 jams
  • LY3IJ
    • Sep 2007
    • 53
    [Jamming] bizhub 350 pc402 jams
    got bh350&pc402
    ghost jams from lct machine has only 50k copies
    everything looks fine in feed unit..
    log shows lct @ vertical transport jams
    where should i look?
  • MCBIG
    • Feb 2012
    • 36
    Re: bizhub 350 pc402 jams
    I've ran into similar problems on many occasions with the PC 402. Recently on a machine with only 89k.
    Most likely, the one way clutches on the pickup and/or feed rollers have failed. I used to remove those clutches and rough up the feed and pickup shafts with scotch brite, clean the rollers and re install... but at this point, I just install new shafts, clutches and rollers while I'm in there and get it all done at once. That way I'm not back a month later worrying with it again and the fix will last. Konica Minolta also now has a "support kit" available that includes various spacers, etc.. which do help increase feed reliability. I am unable to put my finger on the item # for the support kit at the moment, but can get it if interested.
    • dallas
      • Jun 2008
      • 115
      Check Gear 34T (LCT Parts P8/26) for a crack.
      • LY3IJ
        • Sep 2007
        • 53
        2 dallas
        this gear is 4479374802 ?
        2 mcbig
        please # of that kit
        • MCBIG
          • Feb 2012
          • 36
          Support Kit # A11UR92600
