C250 Manual Feed Issue
  • ck1
    • 485
    [Misc] C250 Manual Feed Issue
    I have one C250 manual feed can't detect or no respond at all when put paper at try . any idea ?
    i have try change the P/sensor and clean the sys error data clean still this problem .
  • JustManuals
    • Jan 2006
    • 9838
    Re: C250 Manual Feed Issue
    Paul@justmanuals.com
    • morpk
      • Oct 2010
      • 97
      When you changed the sensor did you take apart the manual feed unit / disconnect the wires it has been a while since i have done this but you might have one of the wires in the wrong spot.
      I could be wrong though you might get a service error if that was the case but maybe double check.
        • 22999
        Does this machine auto-detect the 5 or 6 standard paper sizes from the manual feed bypass? On the newer machines if the paper size adjustment is done wrong or out of adjustment, the machine will never attempt to take the paper. It won't even recognize that paper is in the tray. Just an idea. =^..^=
        • mo0651
          • 1054
          When you touch the auto-paper tab on touch screen, Is the manual tray showing ??? marks? You can do the tray adjustment and see if it changes. I have had to replace the reostat before.
          • ck1
            • 485
            No it show you paper size you setting , but when paper empty still show have paper.
