c 452 colur movement when doing multi copies
  • hjvol
    • Sep 2008
    • 25
    Got a problem with c452 that colour registration moves out when doing multi copies and printing....some examples attached.
    We already changed drum drive section because of p31 code ...code gone but still colours shifts. But what is strange, 1st copy perfect and after 2nd copy or print colour shifting occours till end of job.upon starting new job whole cycle the same....( Happens with black copies and prints too )
    parts changed : all image units , transfer unit ,fusingunit , lazerunit and tested hv board ,controller,io board,lazerunit relayboard...
    Cleaned machine and transferbelt sensors,,,even swopped sensors around...
    Any suggestions pleeeeease!!!!SKMBT_C25012041914490.pdf
  • minimerlin
    • 851
    Re: c 452 colur movement when doing multi copies
    What happens with just Black (K) copies/prints? Have you cleaned the two sensors for the transfer belt/ done colour shift adjust?
    Please do not PM me without asking first.
    • hjvol
      • Sep 2008
      • 25
      .( Happens with black copies too )
      swopped out and cleaned sensors too!!!!!
      • kingarthur
        • 1369
        when you go into the management list....are you getting any "C" codes
        • newmang
          • May 2011
          • 11
          Had something very similar to this last year and turned out to be either the registration roller or the transport roller before it had worn very slightly so the diameter was smaller and hence timing changed. We also changed all the bits you have before finding the answer. Think theres now a tech bulletin for it but Infohub is down at the moment
          • HoonBoy
            • May 2011
            • 130
            Take a good look at the fusing unit entrance actuator/photo interrupter... Could give similar problems if not working properly....
            • RRodgers
              • Jun 2009
              • 1947
              Since I'm looking at this on my phone I can't see your samples so I don't know if you are running 11 x 17 but if you are the I would recommend that you adjust the fuser drive speed. HTH
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                yep, if the fusing loop sensor is stuck in, the fuser will turn too fast resulting in this phenomenon.
                • Spidula
                  Konica Minolta Technician
                  • 83
                  Had this problem today. Stripped and cleaned those sensors and sorted it straight away.
                  Ps. Parts manual pointing to PS41 and PS42, which are the above mentioned sensors, is as clear as mud!
                  • msb
                    I have same problem. Did u found solution?
                    • emujo
                      • Jun 2009
                      • 3009
                      If the image has already been laid down on the paper, how would a slow/fast fuser affect the registration? Just trying to wrap my head around this. Emujo
                      • tech51
                        • 846
                        It doesn't affect the colour reg as such,but it gives a sort of fuzzy or blurred image. It's far more noticeable on a3 paper where you have paper in the fuser and on the second transfer at the same time. The second half of the print can look very different to the first half.
                        • RRodgers
                          • Jun 2009
                          • 1947
                          So did adjusting the fuser line speed fix it?
                          • Gift
                            • Mar 2011
                            • 2459
                            Isn't that the machine type with the sensor/coding discs at the drum gears/main drive going dirty and causing color reg issues?
                            • asrar
                              • Jun 2012
                              • 8
                              Any suggestions pleeeeease!!!![ATTACH]15544[/ATTACH]
                              where are you from ?
