AA=dead fiery?
  • johnnymeg
    • Mar 2012
    • 11
    #16
    Re: AA=dead fiery?
    Originally posted by iduno2much
    There are 2 Fiery patches that can help with AA codes. Install them after you get it up and running.
    Thanks, I had found them. I think the customer caused this problem. there computer was locking up so they were rebooting the fiery and the machine.
    • Issac-brock
      • Jan 2015
      • 61
      #17
      Re: AA=dead fiery?
      Originally posted by DigiMan
      Its an old thread but since ive done this thing A LOT of times i thought i could give some insight to some of the questions.AA mostly occurs when the controller is not properly shutted down(on machine panel Controller->Shut down Fiery) or in some times from power shortages!When you install the software over the old one it takes about 30 mins to complete then u have to shut down and restart(i even wrote a different manual for myself on how to do it cuz with sm sometimes it would still get stuck on AA).when u first open the machine it will run circles of numbers from 01 to 03 with 03 taking the longest,40mins sometimes(its decompressing the files u installed on it) which takes some time(in some machines it takes more time than others,dont rly know why.)I only had once an issue when it would still stay at AA after 3 hours of toying with it and i had to change the hd.Hope i helped anyone(and correct me if i said anything wrong lol ).
      Very helpful, manual is lacking as usual. I had installed a new HDD and OS but after many reboots and lockups it is at AA....reinstalling now. Still on 03 but I'm sure it will be OK. Some kind of network issues and old HDD/OS would not work except on DHCP which is not the same subnet it is supposed to be on. Setting IP static works but machine cannot be seen from the subnet their PC's are on....odd stuff. Also the Config button in CMD WS says to enable web tools however they are enabled, thus the reload.
      • allan
        RTFM!!
        • 5462
        #18
        Re: AA=dead fiery?
        Hehe. I use these fiery boxes for linux pc's. It shows AA if its booted and running. Could be the the interface card or software.
        Whatever
        • rindraintsoa
          • Sep 2010
          • 55
          #19
          Re: AA=dead fiery?
          Hello all,
          I have the same problem, I have finished the new installation of the fiery system software using an usb stick. But when I try to restatrt the fiery I'v got 9A error code or message code on the LED I was wondering if someone can tell me the signification of each code shoed n the led panel. Or at least if someone can telle me what does it mean.
          Thanks a lot
          • Synthohol
            Certified Konica Expert
            • 5846
            #20
            Re: AA=dead fiery?
            Flip the 2 dip switches and do it via network cable into the copier port instead.
            Never liked or trusted the usb method.
              Re: AA=dead fiery?
              Originally posted by rindraintsoa
              Hello all,
              Thanks a lot
              different code than the original thread...
              START YOUR OWN THREAD!
              • feracampos
                • Jul 2021
                • 40
                #22
                Re: AA=dead fiery?
                Hello! Here we go again...
                Recently I'm having this error and I have seen somewhere that exists some patches to solve it.
                I have c7000 with IC-413 fiery, and now it is showing the AA code.
                Accessing by remote desktop, it shows this error:
                Captura de pantalla 2023-02-11 145414.jpgCaptura de pantalla 2023-02-11 145423.jpg
                Anyone has these patches?
                Thank you!
                • Synthohol
                  • 5846
                  #23
                  Re: AA=dead fiery?
                  i would first remove the cover and make sure everything is seated ok like the CPU heatsink.
                  its odd that you can still access RDC when it shows AA on the LED.
                  keep in mind those came with XP on them and of anything tries to update to 7 or 10 there is a special bios and more ram (and a windows 7\10 key) that has to be done first.
                  if it does have XP on it i have the ISO to reinstall the system.
                  • Synthohol
                    • 5846
                    #24
                    Re: AA=dead fiery?
                    i dont think patches will do anything, best to just reinstall from scratch.
                    an hour later all should be ok.
                    PM sent
                    thanks for being a contributor
                    • feracampos
                      • Jul 2021
                      • 40
                      #25
                      Re: AA=dead fiery?
                      Thank you Synthohol!
                      Done reinstalling.
                      It's a XP windows and after reinstalling the System 9 all became ok.
                      Lost paper configs and some adjustments.
                      After checking that all is ok, I have done a clone of the disk with Macrium Reflect, and the Fiery now is running on SSD.
                      Saved the original HDD for backup and future proof.
                      • Synthohol
                        • 5846
                        #26
                        Re: AA=dead fiery?
                        very happy it all worked out.
                        • artivity
                          • May 2023
                          • 12
                          #27
                          Re: AA=dead fiery?
                          PM sent
                          I have same troble today, could you please gimme insight how to fix it, various ways from this thread i did it, but i didnt fix the sytem because i dont undertsand
                          best regards
                          • wjurls
                            • Feb 2017
                            • 498
                            #28
                            Re: AA=dead fiery?
                            Done reinstalling.
                            If you have this running on SSD, I would suggest putting the Fiery on a UPS. I had problems with an IC-415 that I put on an SSD losing all data anytime power went out.
