Error code C2557
  • LennoxD
    • Sep 2011
    • 82
    Error code C2557
    Where is the TCR Sensor located? How can I get to it to clean it?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Error code C2557
    depending on model either dev unit or drum unit or around drum unit looking at drum
    • Max Kilby
      • Oct 2011
      • 30
      What model are you looking at?
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        How about providing the model so someone can actually answer the question and give advice about the possible causes.
        If your a technician, id be considering a different career path.
        • LennoxD
          • Sep 2011
          • 82
          Yha I derserve those comments. The model is Bizhub250
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            Cleaning the sensor will do no good. You need new developer, and if the right side of the drum is scratched, new dv collars and a new drum.
            • LennoxD
              • Sep 2011
              • 82
              I replaced developer and drum unit. Error cleared and a few hrs later customer called back saying error was again displayed
              • habik
                • 2013
                Have you got enough toner in the dev. unit ..is it not starving the dev? check that first. You may have a problem with the toner hopper. take the hopper out completely and clean all sensor at the back for toner empty and toner cartridge present. Next clean the IU cartridge sensor and lastly the Front and rear Calibration sensor. when you pull the transfer belt out you see them. Dust it off and wipe it with alcohol. Put all together and do Full toner add for all colors and image calibration Gradation adjust .
                Let us know how it went.
                Firmwares HERE
                • Albonline
                  • Sep 2008
                  • 1144
                  I think this is a bh250 and he has the worn developer collor symtoms showing up. was the developer unit changed? or just the powder?
                  • Darren King
                    copiertech
                    • 652
                    If you have a ring around the rear of the drum, be sure to replace the transfer roller. That is what causes it, not the worn spacer rollers.
                    Hope this helps.
                    Darren
                    • kmhri5
                      If the machine is old you could have problem with sub hopper, check solenoid on it. The sponge on it can cause it to stick and sub hopper continues to deliver toner to developing unit.
                      • Hansoon
                        • Sep 2007
                        • 3373
                        If you enter:
                        c2557 - Search Results - Copytechnet.com
                        in your browser you'll find around 40 million or so entries about this issue...................
                        Make yourself a coffee and some sandwiches and have a good read
                        Hans
                        โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
