konica minolta c450 image problem
Re: konica minolta c450 image problem
Simple question: Did you thoroughly clean the led printheads? If you did and no change came out of that, why not try and swap the printheads around to see if anything changes?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
and one more thing can I change this? like the yellow print head for the magenta print head? swapping them? thanksComment
I've done it several times, I just can't recall the exact models where I did it. Just check the part no for each printhead. If they match, then you can swap them.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
Color print heads can be swapped with another color, just don't swap it with black. (if I remember correctly)Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
