KM bizhub C450 - ''Need to replace fusing unit''
  • Smiley27
    • Apr 2011
    • 160
    Hi folks, I am getting this message on display( ''Need to replace fusing unit'' ) .. I wonder, do I need to replace it?does this mean there is problem on fusing unit? or its just some counter?
    Thanks.
    • 23009
    Re: KM bizhub C450 - ''Need to replace fusing unit''
    Only if you want to use the machine for printing, copying, or scanning. If you don't change the fuser, it still makes a great doorstop. The fuser is chipped, so only a new fuser will clear the message. =^..^=
    • emujo
      • Jun 2009
      • 3009
      Thanks.
      The "Change Oil" light has come on on my dashboard...Does this mean I have to change the oil, or is it a just some counter. Emujo
      • rinser
        • Mar 2012
        • 9
        you can swap the fuse on the fuser.once you turn it back on, the fuse will blow and the fuser will be reset
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • Smiley27
            • Apr 2011
            • 160
            Ye, thats the solution, but , how to do it? where is it located, Iv been trying to find it,but no success...
            • Shadow
              PHD in Sh!t Disturbing
              • Sep 2011
              • 455
              remove the covers and follow the wires. you are looking for a very small green resistor, it will be covered with plastic and have 2 zip ties.
              this little green resistor is what you need to change. the best tip I can give you is to not solder in the new one. Just wrap the wires
              around the ends of the resistor and then fold over the hard wire on the resistor. If you attempt to solder the new resistor in place you
              run the risk of damaging it, then it becomes useless.
              $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
              • Smiley27
                • Apr 2011
                • 160
                I dont think I understand what You just said, ''Just wrap the wires
                around the ends of the resistor and then fold over the hard wire on the resistor'', so, I dont need a new one, just?...?
                • Shadow
                  • Sep 2011
                  • 455
                  you do need a new resistor, your local electronics place should be able to match it for you.
                  • Smiley27
                    • Apr 2011
                    • 160
                    Hi, I bought 63 mA glass fuse, cut off the old one ( also 64 m A ) , cut the plastic like 1 cm on each wire, put it around fuse's wire, turned on machine,and it works now, but fuse fell off,and machine still works, do I need to place it back? or those 2 wiress are just for reseting?
                    • Albonline
                      • Sep 2008
                      • 1151
                      just to reset counter, the fuse should be open now. so you would need to put it back ? why?
                      • Smiley27
                        • Apr 2011
                        • 160
                        Cos, machine is giving me strange smell when I turn it on, but it works fine, I tought i need to put fuse back,but no sense since there is no electronical circuit since fuse has blown...
                        • rinser
                          • Mar 2012
                          • 9
                          just wrap a bit of insulating tape round the 2 ends of wires just to be safe
