c-4520 bh c6501 cyan not full print appear
  • rangertech
    • Jun 2011
    • 40
    [CQ] c-4520 bh c6501 cyan not full print appear
    Hi all,
    Error code c-4520 in my bh c6501, and i look at the output print with test mode 58 (3 color cyan, magenta n black) cyan have a problem but for another color its good. Look like my attachment file. . . I has been to change drum,charging,1st tranfer roll,write unit, hv detecting cyan, but print cyan still not good
    anybody help me. . .
  • Albonline
    • Sep 2008
    • 1154
    Re: c-4520 bh c6501 cyan not full print appear
    looks like either drum or developer sleeve is damaged
    • inutelkamo
      • Jul 2011
      • 143
      check drum or drum sleeve..
      Check the maylar, it may scrape developer in the developing unit.
      Clean color registration sensor..
      4520 points hand in color registration sensor.
      • ni311
        • May 2008
        • 658
        Color registration error appears that because cyan it is not written properly on the belt. The issue is why it is not written properly. Check the drum if the image is ok and then check the belt, if the image is transferred properly.
        Konica Minolta Error Codes - Explanations and Solutions
