bizhub C452, C2253
    • 23010
    bizhub C452, C2253
    OK. You want to talk about convoluted?
    This all starts with a "Toner Waste Container is Missing." message on a bizhub C452.
    The customer did me the favor of busting off the flag on the lower right corner of the waste bottle. No sweat, right? Wrong. Now it's a C-2253 error. That's a color developing motor error for those of you following along. It occurs during initialization or if reset by front door.
    So I track the voltages back:
    color developing motor M16: CN1-8 and CN1-9: no 24vdc
    On PRCB:
    connection for M16: CN3-2 and CN3-4: still no 24vdc
    ICP13: fuse closed/good
    24vdc from power supply: CN1-1 and CN1-2: still no 24vdc
    On Power Supply (A0P0 R704 11):
    24vdc from power supply: PJ005-1 and PJ005-2: still no 24vdc (also absent at PJ005-3, PJ005-5, PJ005-9, PJ005-10)
    enabled by relay RL801 and RL803, PJ008-12 (DRIVE_RY_REM) and PJ008-14 (INTER_LOCK_SW): 24.8vdc pin 12 to frame ground, pin 14 does not go to ground.
    On PRCB:
    enabled by relay RL801 and RL803 on Power Supply, CN7-3 (DRIVE_RY_REM) and CN7-1 (INTER_LOCK_SW): 24.8vdc pin 3 to frame ground, pin 1 does not go to ground.
    I don't think that I can track this any further back into the PRCB. Do you think it's a PRCB problem? The thing that's got me wondering is the signal (INTER_LOCK_SW). This couldn't come down to an open interlock could it? I've checked the front doors, three on the right side, paper deck right door. Have I missed any?
    I've tried the power supply, no change. I unplugged PJ005 to see if 24vdc returned (possible short?), no change. Since other 24vdc lines are working I removed individual pins PJ005-1, PJ005-3, PJ005-5, PJ005-9, PJ005-10, one at a time to see if I could remove a short, no change. I've removed the other 24vdc connectors, then it asks for imaging units.
    Any thoughts? =^..^=
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: bizhub C452, C2253
    On PRCB:
    On PRCB:
    Actually it could be as simple as one of the dev. units are clogged. Had this happen on a C550 the shutter broke of the dev. unit, was partially closed, toner backed up. it threw a code.
      • 23010
      That was the first thing I checked. They all turn easy. The motor does not even give a twitch during initialization with my thumb on the flywheel. Thanks for taking the time to read my diatribe. =^..^=
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        check the iu connector. I have seen customers slam the iu's and toner so hard they short the connectors out. I believe it was the same type of code (different color). p.s. this is a pain to replace.
        • SmellsHot
          Head Tech
          • 512
          Move the PWB box assy far enough out of the way that you can remove the four screws from the motor and hold it in your hand and see if it will fire up then. This will at least eliminate iu's and binding. If you already replaced power supply, I would then go to PRCB, if you've already reseated connectors. or maybe just start with the motor
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
            • 23010
            Since I cannot even get the 24V without the motor connected, I'm going to order the PRCB.
            You know these newer manuals are just terrible. There isn't one word written to describe the motor driver circuit for the color developing motor. Thanks for your comments. =^..^=
            • Mita-Konica-Tech
              • Jul 2011
              • 76
              Hey Blackcat today was your day off from work.... you had a sick cat to take care of....
              Be nice to Miss Konica....her manuals are better than most...LOL....
                • 23010
                Felix is fine. He has some sort of a corn on his toe. A simple trim.
                Amber got her teeth cleaned. No big deal.
                Cindy got her neutering incision repaired. It had not closed properly. She's very cranky. It will be a long time before she forgives me. =^..^=
                • Hansoon
                  • Sep 2007
                  • 3391
                  Felix, Amber, Cindy.....
                  We want pics, pics, pics...
                  Hans
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    Sometimes you cannot read voltage until the chain of events requires the voltage. I ordered a board for a cassette issue because of no voltage, but it turns out the voltage only appeared after the cassette was shut and the lift mech kicked in.
                      • 23010
                      Hans
                      Cindy Lou:
                      Felix:
                      Amber:
                      • CompyTech
                        Super Tech
                        • Feb 2011
                        • 706
                        Amber sitting next to the drum how cute lol. Do you have them trained to turn a screwdriver yet? Hopefully the board works out for ya. It's hard to diagnose motors cause you take the boards off to test them.. But wait, you can't test them with the board off.. They should really have a mode in the Tech Rep mode to test the motors. The old Konicas had 47 mode. Why they couldn't build that into Test mode in the service mode is beyond me.
                        • SmellsHot
                          Head Tech
                          • 512
                          "Compytech" The new konica color machines(C224,C284,C364,C454,C554,C654,C754) will have the test mode for motors and sensors. And all I can say....is about freakin time!!
                          • kingpd@businessprints.net
                            • 921
                            Haven't had this happen yet to me thank goodness. You probably don't have another machine that you can try to swap a few things out with do you?
                            On PRCB:
                            On PRCB:
                              • 23010
                              Unfortunately, no. I'll be heading out there tomorrow. I'll keep you posted. =^..^=
