minolta bizhub c280 color copy make blue or red lines
  • mikon88
    • Mar 2011
    • 24
    Brand NEW KM bizhub c280 color copy make blue or red lines,
    Print quality is good, b&w copy is good. When i make a color copy the machine makes blue lines or red lines. This is a brand new c280.Scan to PC is ok, print its ok only copy. Lines are vertical.
    I ve got fever: My English isn`t good, so please please forgive me any mistakes.
  • Zeldaman
    • Mar 2011
    • 946
    • mikon88
      • Mar 2011
      • 24
      Re: minolta bizhub c280 color copy make blue or red lines
      Did you repeat all installation steps again?did you clear any data before?
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        No, only turn the machine out & then on again. Then the whole procedure again, then there were no more problems.
        Greetings...
        • kingarthur
          • 1369
          you have to follow the set up instructions exactly as it is written down...
          • mikon88
            • Mar 2011
            • 24
            I will try set up procedure again and i will let you know
            • Julio119
              • 24
              Hi! Mikon88, did you get this resolved, I just took over a setup on KM C458 it is doing same exact thing you described, thanks.
              Julio
              Julio_119@yahoo.com
              • REGSIS
                • May 2016
                • 435
                Read instalation manual. At the end it says to make a color copy and what steps you need to repeat if copy is not OK (if you get cyan & magenta lines).
                • gl0ryh0und
                  • 15
                  There are a couple steps that usually get missed. You must do the gradation adjust, and you must do the install date. Do the gradation adjust exactly as it states in the install instructions. If you don't do both copy and print you will get lines.
                  • allan
                    RTFM!!
                    • 5462
                    Who coined the term "lines of shame"?
                    Whatever
                    • emujo2
                      • Mar 2017
                      • 1579
                      We've been using that term for years...LOL
                      • Synthohol
                        Certified Konica Expert
                        • 5849
                        when they were all blue we called them Yankee Stripes.
                        • Selas
                          • Aug 2017
                          • 1
                          Hi, it is an old thread, but i have similar problem. KM C287 when scanning or copying there are blue or red vertical equal thin lines over the page. Where i should look for problem?
                          Thanks and kind regards,
                          • Bix
                            • Apr 2018
                            • 1421
                            [ATTACH=CONFIG]44822[/ATTACH]
                            Hi, there are thousands of topics where the reason and solution of the problem is explained.
                            You simply didn't go through the installation steps. Rerun the installation manual step by step and the lines will disappear.
