bizhub 920
  • NEOTECH
    • Dec 2010
    • 69
    [Misc] bizhub 920
    hi dear's i have a problem in bizhub 920 pro , i replaced drum ,developer,cleaing,blade and toner due to too dakr back ground image. but still same problem
    i also encounter only 2nd side back ground same machine whats wrong with this machine.
    if any one have a idea plz help me,
    thank's
    • 23007
    Re: bizhub 920
    Did you do any of the drum peculiarity adjustments associated with these parts replacements? If not you'll need to buy a manual to help you do quite a few adjustments. =^..^=
    • NEOTECH
      • Dec 2010
      • 69
      Re: bizhub 920
      dear i have manual and i did drum peculiarity adjustments but not solve tha problem image with back ground.
      • mrwho
        Major Asshole!
        • 4299
        Re: bizhub 920
        Also the transfer/separation corona may be the culprit. Clean it well and rebuild it with new wires and, as blackcat said, run the drum peculiarity adjustments.
        Mascan42
        Ibid
        • maccenterpc
          • Sep 2011
          • 40
          Re: bizhub 920
          I had similar problem, follow the above steps have not solved. Printing with background on the 2nd side.
          I changed the developer unit and the problem was solved. Test with another developer unit.
          Maccenter
          • scottybbb
            • Dec 2010
            • 126
            Re: bizhub 920
            I have had developing units go bad on these machines and leave background on copies.Try replacing developing unit.
            • NEOTECH
              • Dec 2010
              • 69
              Re: bizhub 920
              I did also same thing i replace developer unit and transfer assambly but i will same copy with background not solve problem.
              u have any idea.
              • Albonline
                • Sep 2008
                • 1150
                Re: bizhub 920
                check the hv adjustments aginst the defaults and put them back to factory specs. have had maney units come to me as unfixable , and setting them to specs fixed them.
                • CompyTech
                  Super Tech
                  • Feb 2011
                  • 706
                  Re: bizhub 920
                  Did you also check/replace primary charger as well? Also above post, true. And do Peculiarity Adjustments. Good luck
                  • NEOTECH
                    • Dec 2010
                    • 69
                    Re: bizhub 920
                    i tell some think i did transfer value high like factory 45 set. i make 135 copy low backgroun but not good what u think?
                    • Albonline
                      • Sep 2008
                      • 1150
                      Re: bizhub 920
                      run some more and see if it gets better.
                      • kronical
                        Kronic Copier Ninja
                        • Nov 2009
                        • 230
                        HVPCB pending steps above.
                        • remati
                          • 149
                          Re: bizhub 920
                          thank's
                          ...Tray to change the wires and the grid of the HV 1 corona or change it complete and the same with de transfer/sep corona the wires... but the better is change the complete corona you could have a problem of HV transfer/separation discharge (HV transformer)
                          • methogod
                            • Dec 2008
                            • 921
                            Re: bizhub 920
                            most of the settings take about 500 prints to become active...
                            you using OEM toner?
                            • methogod
                              • Dec 2008
                              • 921
                              Re: bizhub 920
