Pls help
  • jabirplus
    • Jun 2012
    • 3
    [Error Code] Pls help
    having problem with konica Minolta C550 Treble code C-d252 ,any can help me .
  • kennyoleary
    • Aug 2008
    • 23
    • mervyn
      • Jul 2011
      • 90
      Re: Pls help
      Bit dangerous posting full details of tech rep mode to an end user on an open forum .
      • jabirplus
        • Jun 2012
        • 3
        Re: Pls help
        thx dear all, i have solved .
        • ni311
          • May 2008
          • 658
          Re: Pls help
          Next time try to name your topic more accurate, like machine name and problem. It is easy to understand that you need help once you posted here, but you have greater chance of getting the right answer if you are naming your posts according to the forum rules.
          Konica Minolta Error Codes - Explanations and Solutions
          • bunchieattia
            • Aug 2017
            • 4
            Re: Pls help
            How can I reset my c280e Konica Minolta Drum Chip......
            • Synthohol
              Certified Konica Expert
              • 5841
              Re: Pls help
              microwave it for 6 seconds. no more no less.
              then install a new drum.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4712
                Re: Pls help
                Hey Synthohol, I wouldn't be surprised if they take you serious and mic drum
                To bunchieattia. You should start a new thread. Google C280 drum chip. By the way there is no C280 "E"
                • emujo2
                  • Mar 2017
                  • 1579
                  Re: Pls help
                  THANK YOU!!!! Because of morons like this that give away proprietary info, I have to force my customers to change admin passwords, enable CE authentication and change this password to keep hackers and tweakers out of the systems. I can only hope that one of his customers finds this info online, makes some changes and keeps him onsite for 2 days trying to figure out what was screwed up. EMujo
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4712
                    Re: Pls help
                    By the way the original thread where serv code was given out was from 2012.
                    • Synthohol
                      • 5841
                      Re: Pls help
                      I like to poke zombie threads
