Using bizhub C352 Consumables in C250
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] Using bizhub C352 Consumables in C250
    All of the image units (I/U) in a Konica Minolta bizhub C352 look identical to the I/U's in the bizhub C250.
    If I chip a new C352 I/U properly, can I use in the C250?
    What about using a C352 transfer belt in the C250 with the proper fuse reinstalled?
    Thanks in advanced!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Using bizhub C352 Consumables in C250
    i've accidentally put a c250 transfer belt inside a c352 in the past, only realizing when id turned the machine on, half expecting some kind of error code or print quality issue.
    it worked perfectly, so i would assume vise versa would work too.
    • kingarthur
      • 1357
      we have been using C352 consumables in a C250 for about a year now, we discovered this when the customer was given the wrong toner & fitted it, the transfer belts are the same. Another thing i've just discovered, the RADF on the C352 & C203 are also identical, check the parts book, so i'm robbing bits from our old RADFs now.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        identical, except for the different colour casing and the c352 adf has an LED bar on it
        I have half a dozen DF611's & c452 series adf's sitting in my shed for parts ive only ever taken 1 part from them, the black plastic duplex gate and solenoid.
        what could possibly come in handy from them ? I might just take them to the dump.
        • PeterG
          • Jul 2008
          • 177
          Everything, approximately 1 day after you dispose of them.
