bizhub c351 tray 2 and 3 not lifting
  • mrfuser
    • 1617
    Machine not lifting tray 2 and 3. I don't hear motors turn on at all for paper lift. Any ideas?
    Kelly
  • JustManuals
    • Jan 2006
    • 9838
    Re: bizhub c351 tray 2 and 3 not lifting
    Paul@justmanuals.com
    • minimerlin
      • 851
      Kelly
      Is there any paper behind the trays? Any error codes?
      Please do not PM me without asking first.
      • montana
        • Aug 2008
        • 392
        Kelly
        hi...check is there any obstacles on the sensor behind the paper cassette..
        • mrfuser
          • 1617
          No obstacles, no error. Only shows jam at exit of Fuser area that won't clear.
          • mrwho
            Major Asshole!
            • 4299
            Failing the basic steps (the ones mentioned above plus checking the motors themselves, as well as the cabling), I'd search for any burnt ICP, starting on the PWB-MC board.
            EDIT: Jam at the fuser that won't clear - most probably a failing sensor. Try to replace it or, if it is located inside the fusing unit, try with a known working one. Check the fuser connector, it could be badly inserted.
            Mascan42
            Ibid
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              persistant jam at fusing exit is usually the photo sensor at the exit unit in the top of the right hand side door. its totally obvious to see when you open the door. It gets cooked by the fusing unit. Also make sure the actuator moves freely.
              its been a common issue since this p.o.s. engine started out life as a cf2001
