how to repeat image 6 times in c220
  • r_burhan
    • Jul 2025
    [Misc] how to repeat image 6 times in c220
    We have just purchased a Konika Minolta C220. But we are getting option of only 2/4/8 image in "Duplex/Combine" as well as "Image Repeat" option. We want option of 6 images in combine or image repeat. How to add option of 6 image or if there is any other way of repeating image 6 times. Please help!!!!
    • 23006
    Re: how to repeat image 6 times in c220
    The functions on your MFP were designed and implemented by engineers, not technicians. There are a lot of things I'd like to change about the operation panel functions, but alas, we all just try to live with the functions that we are provided. =^..^=
    • r_burhan
      Thanks for your reply..Can you provide any trick/tweak to help me.....its really important...Thankss...
      • kingarthur
        • 1341
        There aren't any....as far as i'm aware....dont think any m/c can do what you want....contact the people who supplied it
        • Dickie
          • Nov 2011
          • 190
          It's easy
          1. do an 8 times image repeat.
          2. Get pair of scissors.
          3. Cut 2 off the page and throw away.
          Job done easy peasy lemon squeezy
            • 23006
            Originally posted by Dickie
            It's easy 1. do an 8 times image repeat. 2. Get pair of scissors. 3. Cut 2 off the page and throw away. Job done easy peasy lemon squeezy
            Damn! You beat me to it. =^..^=
            • r_burhan
              I got the below mail from Konika support, but unable to fulfill my objective. Pls help....""In order to make 6 image repeated copy, please do as follows.- go to image repeat menu- "set range" in "scan range"- select "custom size"- input the size of document so that it is equal to 1/6 od print sizee.g. x=105.0mm y=99.0mm (in case print size is A4)- go to copy main display- select A4 size paper for example then start copyFoe the detail, please refer to image repeat in chapter "Application" of the copier user manual.""
              • r_burhan
                yippeeee...done!!!!
                • habik
                  • 2013
                  Originally posted by r_burhan
                  yippeeee...done!!!!
                  So which one was it. Paper, Scissors or Stone
                  Firmwares HERE
                  • Mita-Konica-Tech
                    • Jul 2011
                    • 76
                    It's Scissors, Rock, Paper....or is it Rock, Paper, Scissors...? Must be British..."Stone"
                      • 23006
                      Czech Republic, but I think he's educated UK. =^..^=
                      • habik
                        • 2013
                        And maybe I am just thinking alphabetically and in Slovak we use stone
                        Firmwares HERE
