c650 controller
  • Synaux
    • Mar 2012
    • 1224
    [Error Code] c650 controller
    This c650's controller (IC 409, I think....I can look it up though) keeps showing codes at random times like F3 and 03.
    I have several manuals for these controllers and similar models, but I cant seem to find a break-down of what the codes themselves denote.
    Thanks guys!
  • Synaux
    • Mar 2012
    • 1224
    Re: c650 controller
    **bump** Seriously? Nobody knows the meanings of the controller codes? I find it very strange that there is no documentation on them...
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Re: c650 controller
      You will need the ic service manual. It has them in it. It also says that any not listed means the system pwb is suspect!
      • Synaux
        • Mar 2012
        • 1224
        Re: c650 controller
        Thanks Mr Spock.
        Are there two service manuals...because I have one and I almost certain they are not in mine.
        Maaaaybe you could give me a page number or email/post the few pages with codes?
        • Mr Spock
          • Aug 2006
          • 2064
          Re: c650 controller
          I have found these only in the ic-408 manual. None of the others seem to have it. These should be the same across most of the models.
          • Synaux
            • Mar 2012
            • 1224
            Re: c650 controller
            Ugh, I don't have any documentation for the IC-408.... :/
            • Mr Spock
              • Aug 2006
              • 2064
              Re: c650 controller
              check this out.
              • Synaux
                • Mar 2012
                • 1224
                Re: c650 controller
                check this out.
                Thanks, I feel much smarter now!
                The codes that I am getting aren't in the list, but I only notice them during working operation...
                As you hinted and stated in the manual "Any other code not listed: Motherboard is faulty."
                I really doubt that is this case (for today). The capacitors are good and it works very well 95% of the time.
                The 409 needs to be restarted often; however, I do recall reading something about a patch for these controllers when they can't come out of standby.
                It will also do some strange things. Sometimes immediately after the copier is turned off the Fiery turns off. Also, I have noticed that sometimes the Fiery will turn off when the copier is on too.
                I assumed this is some sort of standby/power saving, but there doesn't seem to be any rhyme or reason to when it actually does this.
                Anyways, if I can't get the patch that I believe exists, I will probably start a new thread.
                Thanks again, Mr. Spock
                (sorry for rambling)
                • Albonline
                  • Sep 2008
                  • 1144
                  Re: c650 controller
                  here is a list
                  • Mr Spock
                    • Aug 2006
                    • 2064
                    Re: c650 controller
                    Originally posted by Albonline
                    here is a list
                    This is the one I was looking for but could not find. More codes then the other one.
                    • Synaux
                      • Mar 2012
                      • 1224
                      Re: c650 controller
                      here is a list
                      Good stuff, thanks
                      • Synaux
                        • Mar 2012
                        • 1224
                        Re: c650 controller
                        I just ran accross this in
                        SSD Support Solutions
                        IC-409: All Active Solutions
                        March 2011
                        Pages 41-53
                        IC-409 POST Code List (I attached a pdf)
                        Funny how things present themselves when you are looking for them
                        • JustManuals
                          • Jan 2006
                          • 9838
                          Re: c650 controller
                          I have the IC-409 Fiery Service guide, got something to trade? Or email me and I'll give you a break on the price.
                          Paul
                          • Synaux
                            • Mar 2012
                            • 1224
                            Re: c650 controller
                            Paul
                            • Synaux
                              • Mar 2012
                              • 1224
                              Re: c650 controller
                              Thanks for the manual Paul
