bizhub 501 WON'T Print (I think previous post is messed up)
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] bizhub 501 WON'T Print (I think previous post is messed up)
    It does not matter how slowly you go as long as you do not stop. –Confucius
    • 23007
    Re: bizhub 501 WON'T Print (I think previous post is messed up)
    Does it have the IC-207 Print Controller option? You won't be printing without it. There are two little IC sockets on the engine board. The print controller goes in the one labelled "IC", to your right as you're looking at it.
    Print off a configuration page to see if the Print Controller firmware level is listed.
    PS: If you entitle your post with the last word in the title being "print" it is displayed in "printable" mode, with no hyperlinks. Just an interesting little quirk to the website. =^..^=
    • MFPs R Now PCs
      • Jul 2011
      • 156
      Does it have the IC-207 Print Controller option? You won't be printing without it. There are two little IC ports on the engine board. The print controller goes in the one labelled "IC", to your right as you're looking at it.
      Blackcat4866:
      I have attached as a PDF page 1 of the Machine Management List with the firmware on it, I don't believe it's listed, could you please confirm?
        • 23007
        You'll need the Configuration Page > Firmware Version > Print Controller = A0R50Y0-3000-G00-62
        ... or it will be blank in that area. =^..^=
        • JR2ALTA
          • Feb 2010
          • 2033
          Set hdd?
          • MFPs R Now PCs
            • Jul 2011
            • 156
            Got It! Thank you all. IC-207 Missing, Dang It!
              • 23007
              It took me three visits and a little insight from the office manager for me to solve my case. It was relatively common for the sales staff to forget to order little things like print controllers, then wonder why it wouldn't print. =^..^=
              • JR2ALTA
                • Feb 2010
                • 2033
                More amazing, in 2012 Konica sells a copier with a Network Interface Card that can't print.
                • RRodgers
                  • Jun 2009
                  • 1947
                  Can't tell ya how many times I've ran into that. Go out to a customer to set them up for print/scan only to find out it won't print and the chip is missing. What a pain.
                  • kronical
                    Kronic Copier Ninja
                    • Nov 2009
                    • 230
                    More interesting is you can scan without a controller.
                      • 23007
                      True! Like MFPs said. The web interface is fully accessible, and networkable. You can scan ... everything but print. =^..^=
                      • mo0651
                        • 1054
                        I make sure that it looks like a major board when I install that little eeprom. Takes like 5 minutes and that will be $1500. Gets you funny looks from customers.
                        • ModusVivendi
                          I think I may have come across BizHUb 501 without a print controller. I had the user follow the below isntructions for printing a config page, but she says "Printer Settings" option is not there. Could that be a clue, or do I have bad instructions for printing a config page?
                          UTILITY COUNTER>
                          USER SETTINGS>
                          PRINTER SETTINGS>
                          PRINT REPORTS>
                          CONFIGURATION PAGE>
                          START.
                          Or is there a way to determine whether its installed via the web interface?
                            • 23007
                            No, but you can take the back off and check the IC port on the Printer control board. There are two. I believe the one to your right as you look at the back of the machine is for the IC207. =^..^=
                            • ModusVivendi
                              Unfortunately this is at a location in a different state.
                              Sent from my Transformer Prime TF201 using Tapatalk 2
