konica c6500
  • beano
    • 54
    [CQ] konica c6500
    i did a pm today replaced 4 drums , dv's y,m,c,k , 4 charge units transfer belt and transfer rollers ran the adjustments i have whit dots and streaks on all copies went over transfer belt and rollers 3 times everything were put on right
  • 1FRY1
    • 51
    Re: konica c6500
    Samples would be good ?
    • JustManuals
      • Jan 2006
      • 9838
      Re: konica c6500
      Paul@justmanuals.com
      • beano
        • 54
        Re: konica c6500
        • inutelkamo
          • Jul 2011
          • 143
          Re: konica c6500
          Hey there..
          Have you try to clean the PH? or the Mylar tapes below each of dev unit where laser beam passes?
          If done, check your transferbelt, the guide side rubber behind it were probably worn, and in some cases, these rubber scatters and stick with the three rollers, this might cause problem in image transfer..
          Thnx..
          Hope can help.
          • 1FRY1
            • 51
            Re: konica c6500
            is the image like that on the transfer belt ?
            have you checked the black mylar by the transfer roller on the ADU they get damaged just rip it off
            It definatly looks like scraping of the image
            Main thing though is it like that on the belt
            • Albonline
              • Sep 2008
              • 1151
              Re: konica c6500
              There is a batch of bad developer out there, suspect it got overheated in transit.
