error c2801
  • rajmalini
    • Jun 2025
    [Error Code] error c2801
    my printer konica minolta bizhub 501 is not working due to error c2801, pls help and give me solutation
  • Darren King
    copiertech
    • 652
    Re: error c2801
    C-2801 TCR output abnormality.When the TCR output is in
    excess of 3.0 V.
    • rajmalini
      Re: error c2801
      excess of 3.0 V.
      what can i do?
        • 22997
        Re: error c2801
        ... you're not a technician, are you?
        If you have to ask what TCR sensor adjust is, you should be calling a technician. You'll just make it worse, if that is at all possible.
        • Darren King
          copiertech
          • 652
          Re: error c2801
          Call a Konica Minolta service tech
          • JustManuals
            • Jan 2006
            • 9838
            Re: error c2801
            Paul@justmanuals.com
            • Darren King
              copiertech
              • 652
              Re: error c2801
              If you don't have a working knowledge about copier theory, a manual will only get you into a lot of trouble and cost as you will have to call a tech to fix the original problem plus the problems you create by attempting to fix it yourself. CALL A TECH!!!!!!
              • rajmalini
                Re: error c2801
                i have already adjusted the TCR censor and that time error 6 was appearing and after that same error code was coming.
                now tell me what can i do?
                • Imsdal
                  • Aug 2009
                  • 111
                  Re: error c2801
                  Check starter and drum maybe is time to change them
                    • 22997
                    Re: error c2801
                    A professional technician would know that you never run TCR sensor adjust with used and very probably degraded developer. Before you make it worse, please, please, please, get some professional help. You can't do this by yourself. =^..^=
                    • zaini
                      Re: error c2801
                      may be your AIDC sensor dirty
                      • rahadyan himura
                        • Jun 2012
                        • 21
                        Re: error c2801
                        error code C2801 is TCR output abnormality, if you want to solve it just do toner auto supply.
                        in service mode, Imaging process adjustment and then toner auto supply.
                        if still appear and do trouble reset, off your copier and press and hold utility/counter and then on machine same time until trouble reset appear. touch trouble reset and off and on again.
                        i hope this can help u.. ^^
                        • vishore
                          • Oct 2011
                          • 2
                          Re: error c2801
                          If u run TCR error 6 came. Just remove all developer from developer unit and put new developer. Then add toner . Again Run TCR adjust it will work. Best of luck
                          • stanloy4
                            • Jul 2015
                            • 4
                            Re: error c2801 I THIN THIS UT NEEDS HELP AND NOT TO INSULTED LIKE A PROFFESSIONA TEC
                            PLS if u cant assist the guy dont make him look foolish pls try to help him out by submitting possible solutions to him and not make him loose courage in visiting the site ok
                            guy all u need to do is check out forr three major sections .
                            1st make sure that the IDC sensors are in order by properly cleaning them up first then
                            2ndly make sure that developing units are ok with good developer in it not over used developer and that is properly fixed ans seated well
                            then alsp make sure that the first transfer rollers are perfectly in order in the transfer belt section , also make sure that the chargers are properly in order i mean they are clean and still very ok without any rust surface . am sur these should help God Speed bro
                            • Arcadian
                              • Feb 2010
                              • 218
                              Re: error c2801
                              lets be honest here! most copier tech are oblivious, on what to do, you have to find a knowledgeable tech, most tech, play it by ear, or from the service manual, of course its not the tech fault, as company who hires him, and send him out, even though he might say he knows the machine just to keep his job, some tech just drags the issue, making it more costly, while yes there are a few good ones out there, its like a doctor, they are just guessing, unless you goto a specialist, even then, its guess work. sadly that the way it is.
                              i would clean the machine thoroughly, vacuum out all toner residue, literally its hard work, but you might have a bad seal leaking, or a developer seal worn away and toner is going everywhere, cleaning is only a temp solution, you must find the leakage either in the drum or developer. Its good to have a tech one that specializes in your machine. that like finding a needle in a hay sack. good luck.
