error c2801
  • Synthohol
    Certified Konica Expert
    • 5840
    #16
    Re: error c2801
    Originally posted by Arcadian
    lets be honest here! most copier tech are oblivious, on what to do, not and keep their job long.
    you have to find a knowledgeable tech, as they have been advised here multiple times
    most tech, play it by ear, experience or from the service manual, THATS OUR JOB of course its not the tech fault, as company who hires him, if the surgeon sucks it's the medical schools fault? and send him out, even though he might say he knows the machine just to keep his job, lying will not help your reputation or the company's as well some tech just drags the issue, making it more costly, you mean thieves and scoundrels? while yes there are a few good ones out there, its like a doctor, they are just guessing, making an informed decision based on the combination of symptoms, physical evidence, theory and localized component testing and thorough inspection?
    unless you goto a specialist, even then, its guess work. sadly that the way it is. agree to disagree
    i would clean the machine thoroughly, vacuum out all toner residue, literally its hard work, but you might have a bad seal leaking, or a developer seal worn away and toner is going everywhere, cleaning is only a temp solution, you must find the leakage either in the drum or developer. Its good to have a tech one that specializes in your machine. that like finding a needle in a hay sack. good luck.
    and this thread is 14 months old...
    with any luck the machine is a boat anchor by now
      Re: error c2801 I THIN THIS UT NEEDS HELP AND NOT TO INSULTED LIKE A PROFFESSIONA TEC
      Originally posted by stanloy4
      PLS if u cant assist the guy dont make him look foolish pls try to help him out by submitting possible solutions to him and not make him loose courage in visiting the site ok
      guy all u need to do is check out forr three major sections .
      1st make sure that the IDC sensors are in order by properly cleaning them up first then
      2ndly make sure that developing units are ok with good developer in it not over used developer and that is properly fixed ans seated well
      then alsp make sure that the first transfer rollers are perfectly in order in the transfer belt section , also make sure that the chargers are properly in order i mean they are clean and still very ok without any rust surface . am sur these should help God Speed bro
      Frankly I have to agree with BC on this one sounds like the OP has no damn clue on what's going on.
      Even some 'techs' shouldn't be in the industry.
      • Arcadian
        • Feb 2010
        • 218
        #18
        Re: error c2801
        haha so true!!! So true.
        • jwai
          • May 2018
          • 508
          #19
          Re: error c2801
          Originally posted by zaini
          may be your AIDC sensor dirty
          yes, clean it.
