KM 1050e - How much longer can I keep it together
  • Mita-Konica-Tech
    • Jul 2011
    • 76
    #16
    Re: KM 1050e - How much longer can I keep it together
    Originally posted by Kidaver
    Follow up on the PF-602 not lifting. The paper feed assy was not dropping down all the way to turn PS9 off. I assume they are slamming the tray 5 shut but they'll never admit to it but I mentioned it anyways. Just had to realign the gear teeth so it dropped down correctly.
    You think for all the money they spent on these machines, they take a little better care...they probably used their foot to shut the drawer...typical customer....KICK IT.....
    • Mita-Konica-Tech
      • Jul 2011
      • 76
      #17
      Hey, I ordered two "Cut Kits" today for the PRO950's. It should be interesting to install. =^..^=
      Did you get your kits installed yet....???
        • 23009
        #18
        The mounting kits arrived. The recycle units are backordered. I really wanted to do it with the developer change, but may have to do it later since this one machine is dumping toner on the bed like crazy. If they're not here by Monday, I'm changing the developer regardless. =^..^=
