Bizhub C450 print quality problem (Parrallel lines)
  • zalim
    • Mar 2012
    • 44
    Hello guys,
    I have another trouble with C450 model.
    When i print or copy something it get these dark parrallel lines on every print,
    i tried white copy and even it has those dark lines, check the jpg files in attachment.
    I am clueless with this one.
    Thanks in advance guys.
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Bizhub C450 print quality problem (Parrallel lines)
    it looks like you are going to have to replace the MFP board.
    I had the same issue with a C353 and it ended up being the board.
    if you have a spare, take it with you.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • zalim
      • Mar 2012
      • 44
      Well i had my suspicions so the first thing i did was changed MFP board and what i did was i took it and installed it in other C450 and the other one worked fine without any errors, codes or change in print quality but when i put the very same board back on that machine, same problem started again, so i tried to took the good board out from my own machine and installed it in this one, the result was the same so i believe its totally something else.
        • 23009
        If the pattern runs through the image voids, I'd look at the laser. =^..^=
        • Albonline
          • Sep 2008
          • 1151
          swap the whole works in a drawer between the good and bad one .thinkk its the ipb. smaller fk sized board.
          • zalim
            • Mar 2012
            • 44
            okay will get back to you guys once i have tried all of it.
            Thanks for the tips guys
            • kimoncopiers
              • Feb 2011
              • 12
              I have this problem with c350.
              Doing the grattation pattern and looing the color patterns (yello, magenta, cyan, black)
              If you have problem with lazers you will understand which is the problem lazer.
              For examble is yellow laser have problem, yellow pattern will be have white lines.
              • salman
                Bizhub C450 print quality problem (two on cyan lines)
                hi,
                I have a problem in BIZHUB C450,there are two small doted lines in cyan print.
                when I see the print first time I think it was the OPC drum fault and I was changed the new drum and blade but the issue was still there, I clean the charge assembly and laser but nothing happen the problem is still exist. Other 3 sample pages(yellow, magenta, black) is okay the problem only in cyan print, please help me.
                REGARDS,
                Salman.
                • darry1322
                  • Oct 2010
                  • 817
                  Best to start a new thread and post samples so we can see your problem. A lot of folks will see the start of this thread, not notice the dates, and start giving ideas for fixing the original issue.
