I have a konica minolta bizhub c 280 low volume machine it has an intermittent fault.It makes a clicking noise intermittently when it copies or prints and when it makes the noise the copies come out with faded and blank bands in the crosswise direction not in the feed direction on black only.
Colour copies are fine apart from the black element in the copy and single colour copies are fine aaprt from obviously black copies.If the machine doesnt make the noise the black copies or the black element in the colour copier are ok.
The black drum is ok i have changed it and the black developer unit is o.k.The attached copy is a black copy of the test chart and the blank bands are at right angles to the feed direction it runs across the copies not down
