bizhub c360 scanning question
  • avecosat
    • Jun 2012
    • 305
    • TheOwl
      • Nov 2008
      • 1732
      Re: bizhub c360 scanning question
      If your client is running Exchange, then you should get their network guy to read through the document that I posted earlier in this thread which resolves the issues of having to use authenticated accounts with Exchange. The machines will just be allow to scan without any account information entered into them.
      There could be a possibility that your account that you are using from the machine is currently locked for some reason which is why another account may work. If you can prove that the machine works with one account and not another, then you have already proved that the machine is NOT at fault.
      • avecosat
        • Jun 2012
        • 305
        • brent
          • Nov 2008
          • 1214
          #19
          just as a quick followup I am posting new iformation. what the cliend did not tell me is they had a power outage. and the computer guy replaced a switch and a router. then it wouldn't scan. I wish I would have known that. and the ports were turned off. no scan. but the issue has been resolved. as we are scanning to smb now. there is an extra step to scan but it is very reliable. when we scan from the mfp it seems that we can not rename a file. when they get to the computer. it is all nu mbers. is there a way to rename certain scans to keep track of them better on the computer side? at least its scanning
          and it was not the mfp s fault. lol thanks guys
          brent
          • Albonline
            • Sep 2008
            • 1151
            #20
            Depending on model, you can name each scan, in scan settings tab on mfp.
              • 23009
              #21
              Those "numbers" are a date/time stamp:
              SKMBT year month day hour minute second
              You can tell from that which is the most recent.
