Bizhub 250 (black n White)
  • big jase
    • 136
    i have a strange one, intermitantly when copying we get a total Black copy , if you recyle the power the machine runs fine again till the next time!
    This can be fine for a wek or two but then can also fail within the hour
    If at First you don't succeed remove all evidence of ever trying!
  • Darren King
    copiertech
    • 652
    Re: Bizhub 250 (black n White)
    What have you done to try to fix the problem? I don't want to suggest things you have already done.
    Darren
    • big jase
      • 136
      Darren
      tried replacing drum unit (full unit inc dev ) , re flashed firmware , reseated all connections on mfp
      • Darren King
        copiertech
        • 652
        Check contacts inside drum unit opening. Check connectors on high voltage board
          • 22930
          I was thinking more along the lines of exposure lamp failing to light or primary charge loss. Can you reproduce the problem? =^..^=
          • wseyller
            • Sep 2012
            • 1129
            Does it happen only when doing a copy or also when printing. I usually go into Function and run the F12 test pages to eliminate the scanner.
            Sent from my XT875 using Tapatalk 2
            • Hansoon
              • Sep 2007
              • 3349
              Something like that.
              Hans
              “ Sent from my Intel 80286 using MS-DOS 2.0
              https://www.copytechnet.com/images/smilies/biggrin.png
